External audio falls out of sync with 5D video in FCP 7
James Gowdey
on Jun 25, 2012 at 9:40:41 pm
Hi all,
We're experiencing a 5D de-sync with external audio. The external audio starts in sync with the video, but falls off over time.
I'm suspecting the de-sync is because of a framerate issue. What was the standard conversion process for 5D? I set it to process from h.264 to ProRes 422, same frame size, uncompressed audio, but was I supposed to set the framerate to either 59.97 or 29.97 to keep things in sync? Anything else I'm missing?
Any help would be appreciated, thanks!
Michael Gissing
Re: External audio falls out of sync with 5D video in FCP 7
on Jun 25, 2012 at 11:10:17 pm
So common that thousand of posts have been generated by this feature (bug) and Matt Lyon came to the rescue with a tutorial
http://library.creativecow.net/lyon_matt/fixing-fcp-assets/1
Second half deals with correct procedure for importing audio assets into FCP BEFORE syncing. First half deals with a method of fixing it if you have a complex timeline that needs fixing. In your case it is likely that you haven't done a whole lot of editing with drifting sync.
