Audio files in "white"and will not play...
Esther Casas
on Jun 25, 2012 at 4:21:54 pm
Hello everyone!
quick question:
Some of my audio files in FC Pro appear white and not green, also show below a "small square" division, which I never seen before in FC Pro...I think I pressed (apple + T) by mistake...but can't seem to go back!??
Other audio files are ok, will play and are green, and the ones that show the white color were added separately another day, all together...
I've been looking online and I can't find any solution, can anyone help me??!!
thank you!
Esther.
Jerry Hofmann
Re: Audio files in "white"and will not play...
on Jun 25, 2012 at 4:44:22 pm
The white files are offline files. i.e., not connected to media. Look where you saved these and see if they are still there.
The other thing is probably the keyframes button has been pushed. Push it again to close up the tracks. It's the button with green and blue lines on it in the lower left corner of the timeline window.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Esther Casas
on Jun 25, 2012 at 6:23:18 pm
Thank you so much Jerry!
