Sequence compressor settings from DVD
Crosby Buhl
on Jun 25, 2012 at 11:03:01 am
I am editing interviews that were ripped off a DVD handed in by volunteers. It was shot in Ireland and I converted it to quicktime so that fcp could read it. The problem is that when I put the clips into a sequence it requires hours of rendering, it there something I could change my sequence settings to that would do away with the need to render or at least make the rendering time shorter?
thank you
Neil Ryan
Re: Sequence compressor settings from DVD
on Jun 26, 2012 at 4:40:11 am
Either re-rip it in a QuickTime format that FCP likes (such as ProRes) or use what you've got and set your SEQUENCE settings to match. (But that will depend on what format your current QuickTime is. Won't work with Animation codec, for example.)
Neil.
Crosby Buhl
on Jun 26, 2012 at 9:10:30 am
thanks
