Cinema Tools - 25p to 24p - can I just convert the 52min prog? not individual clips
John Doggett-Williams
on Jun 23, 2012 at 11:30:03 pm
I haven't tried Cinema Tools before but have read it's the best way to convert 25fps to 24 for the creation of a DCP file. I have a quicktime movie of the final program (52minutes) and was hoping to simply convert the whole program with a couple of clicks. From what I've read I need to go convert individual clips either in Cinema Tools or back to the original FCP timeline and convert each clip. Is that correct? It would be a nightmare if it is
http://www.fineeyeproductions.com
Rafael Amador
Re: Cinema Tools - 25p to 24p - can I just convert the 52min prog? not individual clips
on Jun 24, 2012 at 4:10:49 am
Wrong information.
What a movie is but a long-long clip?
You can conform the who;e movie at once, but be carefull:
- Is a "destructive process": no way back, so try on a copy.
- The movie will play a 4% slower, so some times will be noticeable the speed change in the audio.
As I said, make a test on a duplicated file.
rafael
http://www.nagavideo.com
on Jun 24, 2012 at 4:56:30 am
Thanks again Raf, good advice. I'll make a copy. Do you (or anyone else) know of a basic cinema tools tutorial?- I've been looking but haven't found anything yet.
By the way I've had a good time with the GH2 but I've found the inaccuracy of the flip out screen and the viewfinder disappointing. Cheers,
Shane Ross
on Jun 24, 2012 at 5:35:15 am
Here's a basic one I made for making clips slow motion. But all the steps are the same.
http://library.creativecow.net/ross_shane/slow-motion_cinema-tools/1
Shane
Little Frog Post
on Jun 24, 2012 at 5:47:13 am
Thanks Shane that's great
