USB 2.0 to eSATA adapter?
Preston Orrick
on Jun 23, 2012 at 11:02:24 pm
I've seen that USB 2.0 to eSATA adapters exist, but does it greatly affect the speed of, let's say, an external hard drive connected to a desktop this way? Or is it better to just get the actual card on the motherboard itself?
Shane Ross
Re: USB 2.0 to eSATA adapter?
on Jun 23, 2012 at 11:20:07 pm
[Preston Orrick] "does it greatly affect the speed of, let's say, an external hard drive connected to a desktop this way?"
Yes. USB2 is a LOT slower than eSATA. And it sends data in packets, not the constant steady stream that eSATA has.
[Preston Orrick] "Or is it better to just get the actual card on the motherboard itself?"
Yeah...MUCH better.
Shane
Little Frog Post
Andrew Rendell
on Jun 24, 2012 at 7:48:00 am
The overall speed of the system is always limited by the speed of the slowest part of the chain. So even if you have an adapter to connect an esata drive to a USB2 connection, the speed that the data gets from drive to computer can't go any faster than the USB2 part of the path.
[EDIT: Aah, didn't look properly, I'm just saying the same thing as Shane really...]
Jerry Hofmann
on Jun 25, 2012 at 4:49:16 pm
To add to this discussion, the only reason those adapters exist is so you could connect an eSATA only drive to a USB port... just for a data transfer...
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
