possible to render out a lower third graphic with alpha channel from FCP?
tad newberry
on Jun 22, 2012 at 6:43:30 pm
i know i should make this in Motion (don't have AE), but for a few reasons, it was better made in FCP. i built a nice lower third graphic with several layers, and wonder if there is a way to render it out as a single layer graphic and plop it on my FCP timeline? i know about nesting layers, but i mean to render this out once as a single layer lower third with alpha channel...
thanks for helping out a bonehead!
__________________________
FCS3
2.66 GHz Quad-Core Mac Pro
6GB RAM
NVIDIA GeForce GT 120
...and a few TeraBytes o' storage
(then it's on to PetaBytes, ExaBytes and MosquitoBytes!)
Shane Ross
Re: possible to render out a lower third graphic with alpha channel from FCP?
on Jun 22, 2012 at 7:01:54 pm
You need to use a ProRes 4444 timeline, as that is the only codec that supports embedded alphas. Make sure that the settings are set for Millions + colors. Then export. And the export needs to be ProRes 4444.
Shane
Little Frog Post
Kylee Peña
on Jun 22, 2012 at 7:03:18 pm
I believe you could make your sequence with the lower third Animation or ProRes 4444 (millions of colors+) and export a self-contained QT file with Current Settings.
blog: kyleesportfolio.com/blog
twitter: @kyl33t
demo: kyleewall.com
tad newberry
on Jun 22, 2012 at 8:09:40 pm
Shane and Kylee, thanks for the reminder about going to 4444 (and don't forget the "+"!). I liked working in FCP a little better, mainly because of what i could do with shadows that Motion wasn't letting me do. Although, from FCP, i keep getting the graphic rendered with chunks of picture missing. Really weird. I'll keep at it, but it's off to a good start. Thanks again...
FCS3
6GB RAM
Neil Ryan
on Jun 26, 2012 at 4:47:49 am
And makes sure your Timeline is NOT rendered before Export.
Neil.
