How best to convert h264 files from Nikon camera into pro res for FCP 7?
Kent Beeson
on Jun 22, 2012 at 4:10:19 pm
Hi
Client has 60 shots and interviews shot on a new NIkon camera 1920x1080p h264 codec...how to use FCP 7.0.3 (or Compressor) to batch these files into pro res 422 .mov's for editing...and he needs to give a transcription service all the audio as well from these files...how best to convert these into usable, small files for transcription?
K
http://www.effective-video.com
Jessica Muth
Re: How best to convert h264 files from Nikon camera into pro res for FCP 7?
on Jun 22, 2012 at 5:47:51 pm
So you just need low-res versions of your interviews for transcription purposes only? I would just take you H.264s and reduce the frame size and output H.264s. Then, at the same time, you can export Apple ProRes 422 HQ files for editing. That way, everything matches.
Jessica Muth
Production Operations Manager
Video Labs
Rockville, MD
301-217-0000
jmuth@videolabs.net
Kent Beeson
on Jun 22, 2012 at 5:51:10 pm
In addition to the audio for transcription I need all 60 shots/I/V's as well ful frame to edit - but FCP 7 won't play well with h264's so I want to convert all quickly to pro res 422 - I know Canon 5D, etc has a software for this but can't find equivalent for Nikon D4 camera - is this any good?
http://www.pavtube.com/hd-video-converter-mac/
Shane Ross
on Jun 22, 2012 at 6:02:55 pm
As Jessica said, use Compressor for BOTH tasks. Use it to make the smaller QT files (with BURNED IN TIMECODE! There's a filter for that in Compressor)...and also the ProRes files.
Shane
Little Frog Post
Kent Beeson
on Jun 22, 2012 at 6:06:59 pm
Thanks for replies - I did tell client to use Compressor but he said he's heard it takes way too long - but I will try it myself -
has anyone good experience with this as well" http://www.pavtube.com/hd-video-converter-mac/
K
Rainer Wirth
on Jun 25, 2012 at 2:34:26 pm
You can use mpeg streamclip.
Rainer
