Compatibility
jack fox
Compatibility
on Jun 21, 2012 at 2:23:40 pm
It has been awhile. In the past I used 24p Advanced for all my video needs, but this time I need to be compatible. The problem is I cannot find a "Scene File" on my DVX100 that is appropriate. I suspect 30fps is what I need. Please advise what and how to choose a "Scene File" that is compatible with other cameras (30fps non-DVX100 SP variety) and is good for interior lighting.
Or can I just shoot in 24p Advanced and just capture in 30fps?
Thank you.
jmf
Jerry Hofmann
Re: Compatibility
on Jun 22, 2012 at 2:25:41 pm
The 30fps is really 29.97... or if you shot 24p (NOT advanced) it too will be 29.97 with a pulldown. The advanced 24p doesn't look all that great if you need to deliver 29.97.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
jack fox
Re: Compatibility
on Jun 26, 2012 at 10:30:08 pm
I guess I can shoot in 24p (not advanced) to get it in the timeline as a 60i interlaced footage that would make it more compatible with other camera rolls? The question is what capture settings to use in FCP?
jmf
jack fox
Re: Compatibility
on Jun 28, 2012 at 9:46:17 pm
Thanks. I'll use Scene File F5. Should the "Rec Speed" be set to "SP" or "LP"?
jmf
