29.97 to 23.98P conversion in FCP X
Penny Clark
on Jun 21, 2012 at 12:45:30 pm
Hello,
I'm working on an edit at the moment where the footage provided is 29.97 animation clips, but for delivery they want it as 23.98P is this possible? And what can be the complications for this? I'm new to these frame rates as I'm used to 25!
Any help would be great.
Jessica Muth
Re: 29.97 to 23.98P conversion in FCP X
on Jun 21, 2012 at 3:33:13 pm
Penny,
There can be many issues with this as the conversion from 29.97 to 23.98 is not recommended. With that conversion process, you are essentially removing a frame to have your video look like it was 23.98 fps. You can create a custom project to edit in the necessary frame rates; however, converting the frames that you need to may cause interlacing or playback issues on the final product. What is your final deliverable supposed to be?
Jessica Muth
Production Operations Manager
Video Labs
Rockville, MD
301-217-0000
jmuth@videolabs.net
Penny Clark
on Jun 21, 2012 at 3:37:51 pm
Thanks Jessica.
They want the final as a digital master 1080p 23.98fps 4:4:4, so I was going to use the Apple Pro Res export. But from the sounds of it I need to talk to the animators about this!
Thanks again.
