Exporting from Final Cut
Raul Ruiz
on Jun 19, 2012 at 8:59:51 pm
Hi there
These are the specs that i need to achieve
http://i744.photobucket.com/albums/xx86/sherdow15/Pipeline_file.png
i can get all these in Final Cut
the only problem is when i export the Audio
the video needs (apparently) two channels or layers of audio (16 bits Big Endian)
i have only achieved just 1 channel
please help
or i will be fired
just kidding
i need it if i want to eat
Shane Ross
Re: Exporting from Final Cut
on Jun 19, 2012 at 10:42:53 pm
You need to export two discreet channels of audio...mono. I have a tutorial on how to do this:
http://library.creativecow.net/ross_shane/multi-audio/1
Shane
Little Frog Post
Raul Ruiz
on Jun 20, 2012 at 2:17:22 am
Hi there
thanks for the reply, it was very very very helpful
now
i have this
http://i744.photobucket.com/albums/xx86/sherdow15/Untitled-1.jpg
there are any other program to export this compression? without the "Apple" compression
and flexible to export multiple channels in Big endian
thank you so much
Shane Ross
on Jun 20, 2012 at 6:59:48 am
I wouldn't worry about the APPLE in the name. I don't think that matters. Not sure about the "little endian" thing. I think most people who have this deliverable use Episode to encode.
Shane
Little Frog Post
Raul Ruiz
on Jun 20, 2012 at 7:07:40 am
i can't export two "Big Endians" channels
FC only let me export two channels of "Little Endians"
where can i change this spec?
Rafael Amador
on Jun 20, 2012 at 1:19:23 pm
If you are exporting with QT Conversion, in the Audio settings uncheck "Little Endian".
rafael
http://www.nagavideo.com
Raul Ruiz
on Jun 20, 2012 at 10:31:50 pm
Thank you very much for all your help
im now trying with "Episode"
