editing flv in fcp with perian plugin
Matthew Stewart
on Jun 19, 2012 at 7:33:28 pm
I am editing a flv I found on youtube in fcp with the help of the perian plug in which makes flv files compatible with quicktime based apps. My problem is that the flv file is 10 fps, is it possible to set the sequence editing timebase to 10 fps? and the audio depth is 32 bit floating point, which is also not available in the sequence audio settings pulldown menu. much appreciated if anyone can help me out with this...
Shane Ross
Re: editing flv in fcp with perian plugin
on Jun 19, 2012 at 7:37:51 pm
Just because you can import it, doesn't mean that it works. FCP doesn't work with FLV, no matter what plugin you get.
You MUST convert the footage to a codec FCP works with. Like ProRes, or if it isn't HD, then DV/NTSC.
Shane
Little Frog Post
Matthew Stewart
on Jun 19, 2012 at 7:42:29 pm
thanks for responding so fast, ive been stumped on this. what do you recommend using to convert the flv into a dv/ntsc file? the clips are 640 x 480.
Shane Ross
on Jun 19, 2012 at 7:43:26 pm
Compressor. Comes with FCP. MPEG STREAMCLIP...free app you can download.
Shane
Little Frog Post
Matthew Stewart
on Jun 19, 2012 at 8:01:33 pm
danke, much obliged.
Steve Eisen
on Jun 19, 2012 at 7:44:44 pm
Try DV NTSC 720x480 or ProRes 720x486.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Creative Pro Users Group
