FLV conversion for FCP7
Corinne Perz
on Jun 19, 2012 at 6:46:15 pm
Has anyone been successful in finding the perfect converter for this process?
Mark Suszko
Re: FLV conversion for FCP7
on Jun 19, 2012 at 10:27:47 pm
Perfect, I don't know; have you tried FLV Crunch? It's free.
Corinne Perz
on Jun 20, 2012 at 1:23:30 am
Thank you for responding. Since I have posted my question, I have been doing extensive research and I found that as a possible solution. I will give it a try tomorrow and I will post my results.
Mark Suszko
on Jun 20, 2012 at 3:55:47 am
I had problems getting FLV crunch 5.0-something to work right, but found an earlier 3.0 version that did work.
Corinne Perz
on Jun 20, 2012 at 1:50:46 pm
Thank you for your suggestions.
I could not find FLV crunch 3.0 version. I downloaded FLV crunch 1.5.0 but when I imported the
video clip which I downloaded from Youtube I got an error message stating there was a problem. GRRR
Mark Suszko
on Jun 20, 2012 at 11:03:09 pm
FLV Crunch is currently somewhere around the 5.0 version number. My co-workers are using it with great success in that version, just something about my own setup didn't like it and wanted the earlier one.
Corinne Perz
on Jun 21, 2012 at 1:42:43 pm
I found FLV 1.5.0. I downloaded one of my videos from Youtube and I still had no luck.
When I place the video the converter the status first shows waiting then status reads Problem.
I can't imagine what I am doing wrong.
Thanks for all your help and suggestions.
Corinne Perz
on Jun 21, 2012 at 2:34:40 pm
FLV crunch 1.5.0 is working just fine when I import videos from my computer and convert them in any format. It is only videos that I download from YouTube that I am having a problem with.
Any suggestions?
-CP
Mark Suszko
on Jun 21, 2012 at 5:15:56 pm
To pull down you tube vids I use http://www.clipconverter.cc. To manipulate the clips after that, I use Squared 5 MPEG Streamclip. Both are free. MPEG Streamclip is absolutely magnificent, a video can-opener that works on just about anything and works well.
