Matching settings, still have to render every clip.
Diego Andres Delfino
on Jun 18, 2012 at 11:49:05 pm
Hi everyone!
I am writing about something that is driving me insane. I am setting up a new default project in Final Cut Pro, and importing video files to it. Whenever I try to place one of these imported clips into the sequence, FCP asks me if I want the sequence to match the clip, and I say yes. When I check the sequence properties, they match the clip's properties. Yet, when I try to import the clips, I have to render them every time, as if the formats did not match. What am I doing wrong?
The video in question is in NTSC CCIR 601, H.264 codec, 873x480, 23.98 fps. I'm running FCP 7.0.3.
Help, please! Thanks in advance.
jon smitherton
Re: Matching settings, still have to render every clip.
on Jun 19, 2012 at 3:18:42 am
You have to transcode the H264 clips to Prores.
Jon
Steve Eisen
on Jun 19, 2012 at 3:40:05 am
[Diego Andres Delfino] "The video in question is in NTSC CCIR 601, H.264 codec, 873x480, 23.98 fps"
Your sequence and footage needs to be an FCP friendly editing codec. ProRes is what you want to convert your clips to.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Creative Pro Users Group
Michael Gissing
on Jun 19, 2012 at 3:51:43 am
And you need to chose a standard editing frame size. Your footage is actually 720 x 480 anamorphic SD so convert to that in ProRes 422.
on Jun 19, 2012 at 9:06:01 pm
Thanks to all for the answers! What should I use to convert it? It's a drag to have to render every time...
Mike Caddell
on Jun 20, 2012 at 5:09:58 pm
Compressor.
