AFX to FCP 7 issue....
James Schroeder
on Jun 17, 2012 at 2:16:51 pm
I've been rendering out several graphics from AFX in different codecs (Animation, ProRes) with no interlacing on them. But when I import them into FCP 7, Final Cut reads these Quiktimes as being interlaced with upper field first, making for some ugly looking graphics. This usually happens when working at 29.97fps, when I'm in a 23.98 project, the graphics are imported properly into FCP. Anyone else have this issue or know what the problem is?
Rafael Amador
Re: AFX to FCP 7 issue....
on Jun 17, 2012 at 2:59:05 pm
Hi James,
Some codecs do not properly flags the field order, so FC has to guess it and often assign the wrong field order.
Just check the files as progressive (NONE) in FC's Browser before to bring them to the time-line.
rafael
http://www.nagavideo.com
Dave LaRonde
on Jun 18, 2012 at 4:39:17 pm
You need to match the frame rates. You're not. Ugliness ensues.
Dave LaRonde
Sr. Promotion Producer
