keyframes
Andrew Ellis
keyframes
on Jun 13, 2012 at 12:10:43 am
I'm having a problem in Final Cut Pro 6.0.6...
I'm trying to create transitions between clips. When I use the pen tool to fade in/fade out...it changes the speed of the clip where I have put the keyframes and the fade out happens much faster. Why does this happen?
thanks...
Andrew
Jerry Hofmann
Re: keyframes
on Jun 13, 2012 at 12:19:44 am
Post your source format and your sequence settings.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Andrew Ellis
Re: keyframes
on Jun 13, 2012 at 9:03:59 pm
the source format...
type: quicktime
frame size: 1280x720
Vid rate: 59.94
Compressor: H.264
sequence settings...
all the same except for Aspect Ratio: HDTV 720P (16:9)
miss anything?
