Mixing Format : NTSC & PAL in FCP 7
Deep Chattopadhyaya
on Jun 11, 2012 at 11:01:32 pm
Need your help to get the workflow right.
Some old DV rush, originally shot in PAL but captured in different postprod facilities.
Finally what reached my FCP 7.0 are :
RUSH 1 : .MOV : Frame size 640 x 480 , Vid rate = 29,97fps and compressor : DV/DVCPRO - NTSC. (90% OF THE RUSH)
RUSH 2 : .MOV : Frame size 720 x 576 , Vid rate = 25 fps and compressor : DV - PAL.
RUSH 3 : .MOV : Frame size 640 x 480 , Vid rate = 30 fps and compressor : H.264
The quality of Rush 1 (90% of total rush) is really bad.
What do you suggest should be the sequence settings and the workflow? (by the way, Digital Cinema Preview with the sequence settings of Rush 1).
Thanx a lot.
