BPAV problems!
Daniel Tyler
BPAV problems!
on Jun 8, 2012 at 5:23:42 pm
I am a film student in college, I was just handed an external hard drive with a bunch of footage I am ment to edit for an internship. the footage is all in individual BPAV folders with a bunch of other stuff included. I have no idea how to handle the situation and I need help!
Dan
Rafael Amador
Re: BPAV problems!
on Jun 8, 2012 at 6:15:28 pm
No idea of which kind of camera are they coming from?
Normally should work putting each folder inside a new folder with a different name and pointing Log&Transfer to those folders.
Depending of the camera you may need some additional software.
Have a look to Shane's tutorial: http://library.creativecow.net/ross_shane/tapeless-workflow_fcp-7/1
rafael
http://www.nagavideo.com
Shane Ross
Re: BPAV problems!
on Jun 8, 2012 at 8:34:07 pm
BPAV...that sounds like XDCAM. You will need the XDCAM TRANSFER UTILITY for that.
http://www.pro.sony.eu/biz/lang/en/eu/content/id/1237477636474/section/prod...
If you have FCP 6, the LOG AND TRANSFER plugin will work. But it doesn't work with FCP 7, oddly.
http://pro.sony.com/bbsc/ssr/micro-xdcam/resource.downloads.bbsccms-assets-...
Shane
Little Frog Post
