Exporting ProRes 422 in smaller file formats
Joel Moorman
on Jun 7, 2012 at 3:50:16 pm
I shoot all of my projects with a 7D, convert the files to ProRes 422 (HQ), edit and then export as 1920x1080 ProRes 422. Always looks great. However, if I attempt to export in any other combination of size and codec in the hopes of having a smaller file size, the image becomes completely pixelated. I realize there will always be some loss in converting to a smaller file, but my results are unwatchable. What am I missing? Shouldn't I be able to export from FCP 7 a variety of files sizes and varying levels of quality?
Thanks for consideration.
Rafael Amador
Re: Exporting ProRes 422 in smaller file formats
on Jun 7, 2012 at 4:08:32 pm
FC is not the best application in the world when downscaling, but normally you can get decent results. Even using QT Conversion you shouldn't get something so awful.
If you have a master exported in Prores, you can use Compressor.
Set the "Frame Control ON", and Better downscaling.
rafael
http://www.nagavideo.com
