What is causing these artifacts and how to fix?
Vikash Autar
on Jun 6, 2012 at 12:21:43 pm
I am quite confused. I gave a DVD to a client who claims they noticed interlacing issues while playing it back, however I did not notice any of these issues on my own DVD player.
I took the DVD to work and did notice the issue slightly on the set up over there.
The project consists of 50i and 25P material and has a resolution of 1440. I encoded the DVD using DVD Studio Pro and the run time is close to 2 hours (DVD5). The file I output from FCP is a ProRes 422 HQ file which looks fine on the computer. I even dragged the final prores file back into FCP and looked at it on a broadcast monitor, all looks fine.
I am really confused what is causing the issue. Is it just bad compression, over compression or actual interlacing?
Please help me solve this mystery.
Image (which is a photo taken of a tv). The issue can been seen at the collar and the jacket.
Dave LaRonde
Re: What is causing these artifacts and how to fix?
on Jun 6, 2012 at 2:33:35 pm
What workflow did you use to create the m2v and ac3 files for authoring in DVDSP? Please tell us step by step.
Dave LaRonde
Sr. Promotion Producer
Vikash Autar
on Jun 11, 2012 at 4:46:55 am
It was a long time ago. The project has been lying a long time around to get fixed. I remember just using DVD SP to do the encoding, I made it fit it to a DVD - 5.
