 | H.264 Issue in FCP 7, is Problem with FCP,AJA or Standards Converter
on Jun 5, 2012 at 2:27:40 pm |
We have a project on FCP 7 converted from ProRess to H.264 Pal 14/9 Aspect ratio. Original material is 16/9 but needs to be displayed on 4/3 hance the 14/9 final. The resolution is Pal SD. We have always used ProRess Timelines average bit rate 3.5mb second, we are Testing H.264 on a custom Ress to match the ProRess settings at 2mb a second.
The H.264 clip plays happily in the Play window Display but when we place clip on Timeline to output through AJA and a stand alone Standards Converter PAL to NTSC, vision is static while audio makes a pop crackle every second or so. By passing the S. Converter PAL to PAL no difference.
I have also tried saying Yes and No to the requester that asks when placing clips on Timeline, neither helps.
Checked various play out and sequence settings but nothing stands out.
I have tried to keep it short but include all steps in workflow.
Any Help welcomed.
Terry
 | Re: H.264 Issue in FCP 7, is Problem with FCP,AJA or Standards Converter on Jun 5, 2012 at 3:03:56 pm |
FCP has never played well with H264 in the timeline. Use the ProRes original to do the standards conversion.
