dv pal to web sequence settings
Paul Joseph
on Jun 2, 2012 at 5:43:05 pm
Hi there
I've got some dv pal anamorphic footage that I need to cut together for a website. It's going to be mixed with some stills, text and graphics created in after effects. I find that dv pal makes text and graphics look horrible. What sequence settings would you suggest for the best looking output?
PJ
Michael Gissing
Re: dv pal to web sequence settings
on Jun 2, 2012 at 11:32:57 pm
ProRes422. DV is lower field so FCP should automatically apply the shift fields filter. As the content is for the web, you might want to consider deinterlacing this footage and using a progressive sequence.
