Just to double check: there is no way to change color in Boris Text 3-D without going through each clip individually and I cannot paste attributes. correct?
Noam Osband
on Jun 1, 2012 at 12:05:01 am
I have a lot of boris 3-D text subtitles and i want to change all their colors from yellow to white. I cannot paste attribute and do this. i need to change each one individually. correct?
noam
Shane Ross
Re: Just to double check: there is no way to change color in Boris Text 3-D without going through each clip individually and I cannot paste attributes. correct?
on Jun 1, 2012 at 12:59:52 am
Yup...gotta be done manually. As Boris titles are a separate interface that you open. THe attributes are invisible to FCP.
Stinks, but...
Shane
Little Frog Post
