Problems capturing 16mm to DV NTSC
Sabina Kato sabinaedonnelly@gmail.com
on May 29, 2012 at 6:33:55 am
Hi
I am in Japan. I shot my footage in 16mm and got it transfered to DV NTSC. What are the correct settings to capture the film? I can play it on Final cut but when I try to capture it, it captures for two seconds and then stops. I have tried it at 29.97 and 23.98 from Easy Capture.
I'd be really grateful for any help.
Shane Ross
Re: Problems capturing 16mm to DV NTSC
on May 29, 2012 at 2:56:55 pm
You need to use the DV/NTSC Easy Setup.
Shane
Little Frog Post
