Compressor taking too long 37 Hours
Shahmir Ahsanullah
on May 28, 2012 at 5:45:43 pm
I've added a "noise filter" to a 26 min movie on FCP and its taking 37 hours to export on compressor. Is it ok to wait or I'm doing something wrong?
The video is shot on HD 1080p
I've added:
1. Two clips "overlay" composition effect - for film effect
2. Color correction to the entire video
3. Added Noise filter to give a little "film grain" effect.
PLEASE HELP ME!!
Shane Ross
Re: Compressor taking too long 37 Hours
on May 28, 2012 at 6:52:18 pm
Did you render it before you sent it to Compressor? That's pretty much a must do thing.
Shane
Little Frog Post
Shahmir Ahsanullah
on May 28, 2012 at 6:58:29 pm
Yes I did a complete render to the video *which took 8 hours*
My system:
Mac Book pro i5
Shane Ross
on May 28, 2012 at 7:05:19 pm
Compressing to what format? And what is your original codec,
Shane
Little Frog Post
Shahmir Ahsanullah
on May 28, 2012 at 7:20:37 pm
Information from Compressor:
Description: H.264 video with stereo AAC audio. Settings based off the source resolution and frame-rate.
File Extension: mov
Estimated size: 3.46 GB/hour of source
Audio Encoder
AAC, Mono, 48.000 kHz
Video Encoder
Format: QT
Width: (100% of source)
Height: (100% of source)
Pixel aspect ratio: Default
Crop: None
Padding: None
Frame rate: (100% of source)
Frame Controls: Automatically selected: Off
Codec Type: H.264
Multi-pass: On, frame reorder: On
Pixel depth: 24
Spatial quality: 75
Min. Spatial quality: 25
Temporal quality: 50
Min. temporal quality: 25
Average data rate: 7.68 (Mbps)
Original Format:
Frame Siza: 1920x1080 HDTV 1080i (16x9)
H.264
Shane Ross
on May 29, 2012 at 4:41:25 am
FCP doesn't work with H.264 files well while editing. That format must be converted to ProRes prior to editing. Sure, editing might go decently, but then exporting will be a problem. As you see.
H264 is never to be edited native in FCP. The format is highly compressed , isn't an I Frame format that FCP needs in order to edit properly.
Shane
Little Frog Post
Shahmir Ahsanullah
on May 29, 2012 at 6:19:20 am
so should I change my sequence settings of FCP from H.264 to ProRes 422 (H.Q)?
