Mixed source media = choppy playback.
Andrew Turner
on May 27, 2012 at 11:38:05 pm
I capture footage on a GoPro and a consumer MiniDV camera and edit in FCP6.
I have recently started playing my movies from a USB stick on my TV. The GoPro footage looks great, as do some After Effects clips. The MiniDV camera shots, however, look jumpy/choppy.
Interestingly, if I encode the FCP movie to a DVD it plays fine so I suspect it's an encoding issue.
The problem files are either MKV or MP4 generated from Handbrake or Quicktime. The MP4 uploaded to Youtube looks fine.
Any ideas ?
Rafael Amador
Re: Mixed source media = choppy playback.
on May 28, 2012 at 2:46:45 am
Which sequence setting and codec did you used in FC.6?
rafael
http://www.nagavideo.com
Andrew Turner
on May 28, 2012 at 8:27:03 am
OK - I'm pretty much a novice here so you may need me to guide me through this.
Firstly, I'm wrong its actually FC5 not 6.
Looking under Audio/Video Settings the Sequence preset is DV Pal (I do live in New Zealand where PAL is standard).
How do I find the actual codec ?
thanks
