HD prores 23.976 timeline conversion to PAL compatible 'equivalent'
stephan kay
on May 27, 2012 at 4:20:14 pm
Hello Forum
I have a project which I shot in 23.976 (1920x1080 24p setting in Canon DSLR NTSC setting).
I now need to screen this also in Europe (a PAL Country) on TV.
What is the best way to convert this project? Cinema Tools? or just dump all clips into a 25p timeline and adjust each clip's length to match the sound?
Or does 23.976 HD 1920x1080 play back as is nowadays in PAL countries? (that would be amazing!)
Any insight would be much appreciated.
-SK
Don Greening
Re: HD prores 23.976 timeline conversion to PAL compatible 'equivalent'
on May 27, 2012 at 7:16:58 pm
[stephan kay] "Or does 23.976 HD 1920x1080 play back as is nowadays in PAL countries? (that would be amazing!)"
You may be in luck because 24p is neither PAL nor is it NTSC. 24p is generally considered a "universal" format that is used to reach the largest possible audience. If you need to show it in Europe then contact the TV carrier who will be hosting your presentation. They will be the ones that have the final say.
- Don
Don Greening
A Vancouver Video Production Company
Reeltime Videoworks
http://www.reeltimevideoworks.com
stephan kay
on May 27, 2012 at 9:00:21 pm
Hello Don
Thanks for your reply! I do love the sound of that for sure!! :)
You made my day.
SK
