Slow and speed single clip fluidly
Elliot Beach
on May 25, 2012 at 9:08:10 am
Hi everyone,
I am the process of editing a music video and I have seen in some other videos that a clip might be moving in slow motion and then suddenly speed up and then slow down again, all in a very smooth and fluid motion.
How can this be done using FCP7/motion, or any other program?
Very new to motion so if that is the program that I will need to use it might take a little bit of explaining please.
E
Jerry Hofmann
Re: Slow and speed single clip fluidly
on May 27, 2012 at 2:29:59 pm
Click open the FCP manual found in the FCP Help menu. Search it on "Variable Speed" and you'll see how to do this in FCP... Not too easy to explain here, but easy enough to do with those instructions.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Elliot Beach
on May 28, 2012 at 11:17:35 pm
Nothing came up in the help but I Googled Variable Speed and got what I needed. Thanks!
