 | MXF Playback on timeline only playing 3 frames at a time!!
on May 24, 2012 at 5:56:17 pm |
Ok so this is a strange problem. First off Im playing .MXF files in FCP7 with a Calibrated plugin (great plugin btw) anyhow after merging my separate audio and video files together I put them in the timeline.
Everything works fine up until this point.
Now whenever I play whatever is in the timeline, Final Cut will only playback short 3 frame bursts then it pauses. I have rendered everything and when I export to a quicktime reference the sequence plays back perfectly. What am I doing wrong to make it playback like this?
 | Re: MXF Playback on timeline only playing 3 frames at a time!! on May 24, 2012 at 6:45:57 pm |
Where are these files stored? Meaning what hard drive, and how is it connected?
Which version of FCP? running on what machine? How much RAM do you have?
Shane
Little Frog Post
Read my blog,
Little Frog in High Def
