Is there a way to change an audio keyframe in the timeline without changing the level?
Noam Osband
on May 23, 2012 at 6:27:07 am
I sometimes used the pen tool in the timeline to move audio keyframes. That said, I usually only want to change where it is in the clip and not the level, but when i move it, I always worry I'm changing the level.
Shane Ross
Re: Is there a way to change an audio keyframe in the timeline without changing the level?
on May 23, 2012 at 7:17:22 am
Hold the SHIFT key as you move it left or right.
Shane
Little Frog Post
