FCP 7 squeezes videos on export
Albert Aguilera
on May 22, 2012 at 11:05:41 pm
Im working w several different SD videos. I am placing these SD 4x3 videos into 1080p timelines. Its a prores 422 timeline.
My sequence settings are as follows:
1920x1080
HDTV 1080i (16x9)
Pixel Aspect Ratio 1440x1080
When I place the SD 4x3 videos into the timeline is asks if I want to set the timeline to the video and I say no. I get the pillar boxes and thats fine. I get a 4x3 SD video inside a 1080 16x9 box.
When I go to export I leave it as sequence settings and the final product is squeezed.
Any ideas?
-Albert
Bret Williams
Re: FCP 7 squeezes videos on export
on May 22, 2012 at 11:35:17 pm
Why isn't your pixel aspect square? There's your problem.
Albert Aguilera
on May 22, 2012 at 11:56:36 pm
When I make the pixel aspect square my QT comes out 4x3 pinched and not 16x9 pinched. Im looking for the 4x3 image to remain 4x3 within a 16x9 box
-Albert
Rafael Amador
on May 23, 2012 at 3:10:45 am
I agree with Bret.
You need a 1920x1080 SQ pixel sequence.
Make sure that the SD stuff shows the proper settings on the Browser.
rafael
http://www.nagavideo.com
Bret Williams
on May 23, 2012 at 5:38:07 am
True. Everything has to line up. What are the specs of the SD video? 720x480 DV or 720x486? In either case they wouldn't be square pixels as SD isn't square pixel.
Albert Aguilera
on May 23, 2012 at 5:39:59 am
640x480 are the dimensions.
Ive been creating dif combo of test files. This is a nightmare.
-Albert
Alexander Kallas
on May 23, 2012 at 9:51:04 am
[Albert Aguilera] "Im working w several different SD videos. I am placing these SD 4x3 videos into 1080p timelines. Its a prores 422 timeline."
I'll ask the obvious question, why are you trying to do this, it won't improve the quality, rather it will degrade it.
Cheers
Alexander
Rafael Amador
on May 23, 2012 at 10:42:50 am
[Albert Aguilera] "640x480 are the dimensions."
Then make sure that in the Browser has Squared pixels.
When you drop that on a 1920x1080 SQ pixels sequence you will get the picture pillar-boxed but keeping the original 4x3 aspect.
Make sure nothing is checked as Anamorphic.
rafael
Albert Aguilera
on May 23, 2012 at 4:19:59 pm
The solution by Rafael has worked!
Thanks a lot guys. I appreciate the help.
-Albert
Albert Aguilera
on May 23, 2012 at 4:12:11 pm
Im doing this bc the client wants to put a 4x3 video in a 16x9 box. They dont care about the pillar box. Ya Im not trying to make SD footage HD.
-Albert
Albert Aguilera
on May 23, 2012 at 4:42:42 pm
One other thing i saw was that my timeline was set to DVCpro and that made a 4:3 export regardless of the dimensions of the timeline. When I made it prores it worked the way it was suppose too.
The "distort" too was also set to 68.75 instead of 33
-Albert
