Eric Lochstampfor
on May 22, 2012 at 1:37:05 pm
Was using compressor to export using the lan streaming settings yesterday and would get as far as pressing the submit button and then it just hangs up. Doens't crash just sits and says "waiting" on the process window.
Was working fine last week, but early yesterday I did try to make a droplet from the LAN settings which also did not work. Also droplets I've used in the past are not working either.
Left it overnight to see if it woudl start eventually and this morning it was still "waiting...".
FCP 7.0.3
Compressor 3.5.3
Have tried running compressor repair already, no avail.
Was thinking of trashing prefs but am not 100% sure where they reside in my library and don't want to simply delete stuff.
Any help is greatly appreciated, trying to avoid a re-install if possible.
Jim Murphy
Re: Compressor..waiting...
on May 22, 2012 at 8:15:33 pm
Have you checked the Batch window to see if there are any other processes running without you knowing?
© 2018 All Rights Reserved
