e-cinema QT to .mpg best converter
John Doggett-Williams
on May 21, 2012 at 2:08:41 pm
I'm trying to find a good quality converter to go from quicktime to mpeg2-ps hd (which ends up as a .mpg). I'm using icoolsoft which can boost the vid bitrate to 20000kbps and audio up to 320kbps. The quality was fine for the e cinema screen but I was curious because the 52minute HDV program shrunk to 4.3gig. I heard the files for that length can be much larger.
Any suggestions?
http://www.fineeyeproductions.com
Neil Ryan
Re: e-cinema QT to .mpg best converter
on May 22, 2012 at 7:51:18 am
I can recommend someone local if you want to outsource it and relieve yourself of any headaches.
Neil.
