 | Uprezzing Select clips in FCP
on May 20, 2012 at 6:43:55 am |
Hey,
I'm on FCP 7.03 and am trying to uprezz select footage in a sequence that contains mostly HD footage but a bunch of low res footage as well. All graphics and file-based footage in the sequence are at full res and tape-based footage at low res. How do I go about decomposing the sequence to only reveal the offline, low res footage?
Hopefully this made sense. Thank you
 | Re: Uprezzing Select clips in FCP on May 20, 2012 at 7:11:22 am |
You'll need to find it on your own. And then move it to higher layers so you can separate it. FCP won't find it for you.
Shane
Little Frog Post
Read my blog,
Little Frog in High Def
