How to make multiple JPEGs from single frames in FCP
Jodie Myers
on May 16, 2012 at 6:18:45 am
I know how to make a JPEG from a single frame in FCP, but how do I create 300 JPEGs from 300 single frames w/o having to go through the 3 step process for each one?
I have a project to hand in by the 17th, so I hope someone can help me out sooner than later.
Neil Patience
Re: How to make multiple JPEGs from single frames in FCP
on May 16, 2012 at 7:21:19 pm
You need to use Export Using Quicktime Conversion.
Then select Format - Image Sequence. Select format for JPG and the correct frame rate.
Export and you will get 300 JPEG frames automatically.
best wishes
Neil
http://www.patience.tv
Jodie Myers
on May 16, 2012 at 7:27:08 pm
Thanks! I actually figured it out last night, what a life saver!!
Cheers,
Jodie
