Exporting XML with Motion Parameters
Patrick Simpson
on May 16, 2012 at 1:26:39 am
I'm preparing to send a project to a colorist via EDL.
The project includes a bunch of clips with Motion Tab paramater adjustments such as Scale and Center (which don't transfer with the EDL). I'm trying to figure out a way to create a list of the clips with Motion Tab parameter adjustments. I've been searching around and I can't believe there's not a way to open an XML as a spreadsheet with fields something like this...
Name---------------Scale--Center
MVI_0995.MOV---118----0, -119
MVI_0851.MOV---117----0, -78
...so that the colorist can easily make these adjustments manually on the clips. There are some utilities that will parse an XML into a spreadsheet format (FCP XML Analyzer, XML2Text, readXML) but they only seem to list the other attributes like, in/out points, duration and comments. Any ideas?
Jeremy Garchow
Re: Exporting XML with Motion Parameters
on May 16, 2012 at 2:19:13 pm
What system are you going to?
Can you send a reference movie for matching?
Patrick Simpson
on May 16, 2012 at 2:39:44 pm
Quantel Pablo Neo. I suppose we could do the reference QT but the list would ensure precision.
Jeremy Garchow
on May 16, 2012 at 3:07:10 pm
Maybe this will help?
It's free.
http://automaticduck.com/products/pefcp/
