Problem with Magic Bullet Looks
Juan Vera
on May 11, 2012 at 6:36:47 pm
I install the "Magic Bullet Looks", and for some reason, I listed all the "MY FIRES" but not the pluging of "Looks". I do not know ifsomething wrong or something happened. Is there another program to get a result similar to "MBL"?
Tony Brittan
Re: Problem with Magic Bullet Looks
on May 11, 2012 at 8:27:39 pm
Looks comes with a set of companion plugins called "Mis-Fire". They are film looks plugs you can add on and some are actually pretty good. You might not've selected to install all of your plugins what y
Tony Brittan
on May 11, 2012 at 8:29:05 pm
Sorry...continued...you installed the package. Might try to re-install!
Juan Vera
on May 11, 2012 at 9:36:11 pm
I already re-installed several times, I do not work out.
Like magic bullet looks, magic bullet mojo, and colorist II, I do not work. At least the MBL, I installed a portion of the plugin (My Fires). The install correctly, but not in the FCS or folder.
