Garbage matte layer postion in effects stack
anthony Faulkner
on May 9, 2012 at 1:13:35 am
Does it matter in terms of computing power and render times where the garbage matte is placed in a series of effects applied to a composite clip?
Is it better to leave it off where possible?
Jerry Hofmann
Re: Garbage matte layer postion in effects stack
on May 9, 2012 at 1:44:33 am
Don't think it would matter when in the list it's added.
The second question I don't quite understand, other than the fewer the filters the faster the render probably.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: http://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
http://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Rafael Amador
on May 9, 2012 at 9:23:33 am
[anthony Faulkner] "Does it matter in terms of computing power and render times where the garbage matte is placed in a series of effects applied to a composite clip?"
In theory, applying the Garbage matte first should reduce the rendering time cause the other effects will be applied to only part of the picture (the matted one).
Not sure if in real life this happens.
rafael
http://www.nagavideo.com
