sequence problem
Fernando Luchsinger
sequence problem
on May 7, 2012 at 8:49:20 pm
HI:
When I create a new sequence, the final cut create automatically a few others sequences with strange names like: tmp. iSdgF
Then when I select my sequence (with the real name that I gived) the program is unable to open, but when I select the other (tmp.Fggd, etc) everything is ok.
I had try to rename the sequence but nothing happen. If I put a new name the final cut is unable to open again.
thanks
FL
Shane Ross
Re: sequence problem
on May 7, 2012 at 9:08:41 pm
Running FCP 7.0? Update that to 7.0.3 if you are. Use the SOFTWARE UPDATE option in the SYSTEM PREFERENCES.
This is a known bug.
Shane
Little Frog Post
Fernando Luchsinger
on May 7, 2012 at 9:37:14 pm
Hi Shane :
Thanks, but I have the FCP 7.0.3
Anything else?
