FCP 720P Layback to HDCAM SR not ending on the right field, any suggestions
Dylan Jones
on May 6, 2012 at 10:45:06 pm
I am trying to layoff a 720P 59.94 DF Apple Pro res HQ sequence from Final cut V7 With AJA Kona 3 card. The out frame is ending on Field 1 when it should carry to field 2 resulting in the preceeding shot to come 1 field/frame early. There is no offset for half a frame in FCP so I am not sure what I can do.
I've tried: All AJA kona pulldown options, single field/full frame option, offset +1 & - 1 Frame, +/-2 frame etc. Any other suggestions kindly appreciated
Thanks in Advance, Dylan
323 819 6487
dylan@zerocompression.com
http://www.zerocompression.com
Shane Ross
Re: FCP 720P Layback to HDCAM SR not ending on the right field, any suggestions
on May 7, 2012 at 2:32:24 am
Are you cross converting to 1080i? Because 720p has no fields...only full frames.
Shane
Little Frog Post
Dylan Jones
on May 7, 2012 at 3:52:05 am
Nope, 720P straight to 720P HDCAM SR. So it is as if the picture is going out at frame 58 instead of 59, hope that makes sense
Dylan Jones
Owner / Editor
Web: http://www.zerocompression.com
Email dylan@zerocompression.com
(323) 819-6487
