Low Image Quality When Recompressing to Apple ProRes 422
sophie lee
on May 5, 2012 at 10:11:02 pm
I am trying to edit an HD 3d animation on a macbook pro with Final Cut Pro 6. The only possible way to achieve this seemed to be to recompress the existing FCP project into a ProRes 422 codec, edit, and then change the codec when it came to rendering on a more powerful computer. However, the ProRes project has such poor image quality than I am unable to edit. Evidently I've done something wrong as I understood that ProRes would provide the same image quality but with much faster playback than my original files.
This has been my workflow so far:
1. Save the image sequences of the rendered animation in Quicktime Pro as a quicktime movie with a .tga codec
2. Import all the QT files into FCP
3. Recompress the whole project using the Media Manager as ProRes 422 1920x1080 30p 48kHz and save as a duplicate project
4. When I open that and try to work with it the image quality is poor
I have also tried re-saving the image sequences in QT with a ProRes 422 codec to start with, but again the image quality is no good.
Any help would be MUCH appreciated.
Many Thanks.
Rafael Amador
Re: Low Image Quality When Recompressing to Apple ProRes 422
on May 6, 2012 at 2:15:34 pm
[sophie lee] "1. Save the image sequences of the rendered animation in Quicktime Pro as a quicktime movie with a .tga codec"
Save the image sequences directly as Prores.
rafael
http://www.nagavideo.com
