Sound icon on a .mov file
Eric Delgado
on May 5, 2012 at 8:04:58 pm
I have an AJA IO HD hooked to a MacPro working in order using FCP 7, without changes it is making Quicktime files with the Sound icons.
This .mov file when opened in Quicktime it won't display video, but when imported in FCP works fine.
If I export from FCP, the mov file come out perfect.
Can't figure this one out
Eric Delgado
PES Films
Shane Ross
Re: Sound icon on a .mov file
on May 5, 2012 at 11:21:52 pm
You lost me. The IO HD only makes quicktimes when you use it to CAPTURE video. So how it is making a QT file from Final Cut Pro? It doesn't do that.
Shane
Little Frog Post
Eric Delgado
on May 6, 2012 at 6:07:00 am
I was ingesting in final cut pro using the Aja IO HD. After capturing
the quicktime file created only showed in QuickLook as an sound file, and when opened in QT it only played sound. But when placed in a FCP sequence it played perfectly, also I was able to export a QT which displayed perfectly in Quick Look.
Anyway I had installed a month ago AJA's mos recent update (10.1), I uninstalled and installed 9.05. After this FCP preferences were reseted and it started behaving fine.
thanks anyway
Eric Delgado
PES Films
Michael Gissing
on May 6, 2012 at 7:21:33 am
Check the AJA drivers very carefully as there is a different set for using with FCPX and FCP7
