Problems with Twixtor in FCP7: 10% slowmo ist freezing every 5 frames
Mladen Pavlovic
on May 4, 2012 at 9:00:39 pm
I have converted an EOS5DMarkII clip with MPEGStreamclip to AppleProRes.
Then I have import the clip in FCP. The settings for the sequence have been adopted to the settings of the clip. I have followed the tutorial of RE:Vision Effects on how to do slowmotion using the twixtor plugin in FCP.
In the rendered clip I have the problem, that 5 frames are rendered correctly in 10% slowmo an then 5 still frames are following, than 5 correct ones, and than 5 stills again.
I have found some posts, whiche are explaining this problem with a framerate issue. But in the FCP twixtor plugin there are no settings for the frame rate. The only thing that I can do is to set the sequence setting same as the clip setting.
Thanks for any tips.
Tong Harry
Re: Problems with Twixtor in FCP7: 10% slowmo ist freezing every 5 frames
on Sep 21, 2012 at 8:36:09 am
The same problem,four freeze frames in every 5 frames.
