Arri Alexa proxies in final cut??
Daniel Jimenez
on May 4, 2012 at 8:36:45 pm
hi, i need to do an offline editing with some Arri Alexa footage, the issue is that I need to create proxies to use it in mi home station, how should i create this proxies?? which program should i use?? is there any log and transfer for alexa footage?? please help
Shane Ross
Re: Arri Alexa proxies in final cut??
on May 4, 2012 at 9:40:15 pm
[Daniel Jimenez] "how should i create this proxies??"
Import the full res footage. Then use the MEDIA MANAGER and the RECOMPRESS option.
[Daniel Jimenez] "which program should i use??"
FCP. Anything else and you are looking at a lot of work, and a lot of issues reconnecting the media.
[Daniel Jimenez] " is there any log and transfer for alexa footage??"
ALEXA raw? Or is it being shot ProRes? If ProRes, then L&T isn't needed, it's already in the format needed. If Raw...then the camera should be making the proxies itself.
http://www.arrimedia.com/alexa/workflow
Shane
Little Frog Post
Daniel Jimenez
on May 5, 2012 at 5:01:16 pm
i do some test with some clips, the properties are Apple pro ress 444 24fps, and i did the proxies with this setting Apple pro Ress (proxy) 24p 48khz, and when i finished, a message appear that says that my files arent in the same framerate, which setting should i use instead?? thanks guys
Nick Meyers
on May 8, 2012 at 11:00:56 am
the FCP preset, while labeled 24p, has a frame rate of 23.98.
you need to duplicate the pre-set, change the frame rate to 24, and use that to export.
cheers,
nick
