Frame Rates
Sky Spooner
Frame Rates
on May 3, 2012 at 7:13:43 pm
I want to encode a 10 Bit Uncompressed QT file into an M2V.
The uncompressed file has a frame rate of 23.98.
When I change the sequence frame rate to 23.98 several windows close including the Timeline and others. So I can't proceed. The windows options to bring those windows back are also greyed out.
This happens even when I do nothing but open FCP and simply change the frame rate to 23.97. Those windows disappear and I'm unable to bring them back
How can I get those windows to open?
Shane Ross
Re: Frame Rates
on May 3, 2012 at 7:25:07 pm
How do you change the sequence frame rate?
Shane
Little Frog Post
Sky Spooner
Re: Frame Rates
on May 3, 2012 at 8:22:14 pm
I right clicked on the sequence and went to settings where I changed the frame rate to 23.98 from 29.97. Suddenly my timeline vanished and I can't get it back.
Dave LaRonde
Re: Frame Rates
on May 3, 2012 at 8:29:35 pm
[Sky Spooner] "I want to encode a 10 Bit Uncompressed QT file into an M2V. "
Compressor can do that. And DVD Studio Pro can make 23.976 (aka 23.98) DVDs.
Dave LaRonde
Sr. Promotion Producer
Sky Spooner
Re: Frame Rates
on May 3, 2012 at 8:38:39 pm
ok so if I just change the frame rate in the compressor's inspector to 23.98 for the M2V all should work?
Dave LaRonde
Re: Frame Rates
on May 3, 2012 at 8:45:11 pm
You said the file was already at 23.976. Why would you need to change it?
Dave LaRonde
Sky Spooner
Re: Frame Rates
on May 3, 2012 at 8:55:03 pm
Because the sequence in FCP is set to 29.97 so when I export to Compressor it has that frame rate already set.
Are you saying I should just use compressor as a stand alone. And not even bother with final cut?
Dave LaRonde
Re: Frame Rates
on May 3, 2012 at 8:59:26 pm
Sure, why not? Unless you need to add something to the file, there's no need to even open FCP. Compressor & DVDSP will do the trick.
Dave LaRonde
