Question about exporting XML
Chris Jones
on May 3, 2012 at 6:42:47 pm
(I posted this under the Davini forum originally - but thought maybe the problem I'm having might be what I'm doing (or not doing) in FCP)
This is what I'm trying to do:
1) Create proxy ProRes files in Resolve from original DPX files.
a. [In Resolve] I'm using Scene Detection to split 5 min DPX clips into the different takes within the clip and doing a simple grade for each take.
b. I'm then Rendering out ProRes files for each of the split takes to a new folder.
2) I am then renaming the new clips(files) to its Scene-Shot-Take name: For example: from 164884 to 48C_01_01
3) [Then in FCP7] I'm editing the shots and exporting an XML.
4) [Then back in Resolve] I'm trying to import the original DPX source files for final grading.
But this is what is happening:
When I load the XML and navigate to the folder with the source DXP files Resolve tells me all the newly named files can't be found.
I thought XML linked to the Timecode? I figured as long as I navigated Resolve to the correct folder. It would find the correct timecode and load the correct DPX.
Thanks in advance for any help with this.
Andreas Kiel
Re: Question about exporting XML
on May 5, 2012 at 1:51:46 pm
There is no real timecode in FCP XML rather then for the original files.
There is is a link to the source files which is in your case the most important one.
Spherico
http://www.spherico.com/filmtools
