ProRes 422 - 12 or more tracks of audio - constant rendering?
Tom Barton-Humphreys
on May 3, 2012 at 9:14:05 am
Hi
As far as I know, my project is set up correctly. I don't have to render audio or video edits, so I know my media is all the correct codec.
However, when layered up, say 12 or more audio tracks, when ever a keyframe is edited that section requires rendering? Thoughts?
Tom
Rafael Amador
Re: ProRes 422 - 12 or more tracks of audio - constant rendering?
on May 3, 2012 at 1:18:11 pm
Too many tracks.
rafael
http://www.nagavideo.com
Jeremy Garchow
on May 3, 2012 at 1:46:47 pm
There's preferences to set the number of real time audio tracks.
The default might be 8, can't remember off hand.
If you have many filters on those tracks, it will require a render.
If you have no filters, check your preferences.
Jeremy
Shane Ross
on May 3, 2012 at 2:12:25 pm
User settings...that's where the Real Time audio tracks are. Yes, it defaults to 8. Set it to 32.
Shane
Little Frog Post
on May 3, 2012 at 2:52:13 pm
Perfect, that worked a charm! Thanks, Tom
