Jumpy Transitions in Final Cut Pro
Daniel Morgan
on May 2, 2012 at 1:38:12 am
Whenever I put Cross Dissolves or Fade In/Fade Out on the timeline it causes the clip to jump when it's coming out of the transition. If I export it, will this show up in the final product? How do I fix this problem. I was hoping it was just a glitch.
Tony Brittan
Re: Jumpy Transitions in Final Cut Pro
on May 2, 2012 at 11:24:57 am
Is your footage from a DSLR or other file based camera and is it used in your project without transcoding it to something edit friendly like Prores first? FCP 6/7 doesn't like h.264 footage...or basically anything from most file based cams natively. That's the most common cause of the problem you're reporting.
Tony Brittan
Island Shore Productions
Pfi
