FCP 7.0.3 Multicam problem after adding transitions
David Stembridge
on May 1, 2012 at 8:01:46 pm
I've been using multicam for year, was working on a project tonight, performance with 2 camera angles. Video tracks in great shape; after editing the 1 hour sequence, I did a little color correction, and rendered, then added dissolves to groups of edits.
Playing back after rendering there are jumps around the dissolves. I tested a very short sample, and exported, and there now appears to be a syncing issue. If I add both angles to a time line, and loew the opacity of the top angle, any where I scan, the angles are in sync, tightly.
Could my work flow be causing this?
(the first several dissolves are fine; watch through, and you'll see some of the problem I've having)
multicam issues
Jerry Hofmann
Re: FCP 7.0.3 Multicam problem after adding transitions
on May 3, 2012 at 4:08:01 pm
Have you tried collapsing the multiclips before the render? Might work to fix you up...
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog:
Current DVD:
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17" MBP, Matrox MXO2 with MAX - Cinema Displays I have a 22" that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
© 2018 All Rights Reserved
