Color Grade multiclip angle in FCP 7... after editing?
David Stembridge
on Apr 30, 2012 at 8:26:44 pm
I didn't realize I'd need to adjust my levels till I was a good bit in editing a multiclip performance with 2 camera angles.
Is it possible to color grade the original clip.... and switch it out with the referenced clip in my multiclip, and still be recognized in my edited multiclip?
Shane Ross
Re: Color Grade multiclip angle in FCP 7... after editing?
on Apr 30, 2012 at 10:09:24 pm
Color Correct one angle. Copy that clip. Do an APPLE-F to find all instances of that name in the sequence. Then PASTE ATTRIBUTES...FILTERS to those clips. You have now color corrected all instances of that angle.
Repeat for other angles.
Shane
Little Frog Post
