remove optimized media
Philippe De Neve
on Apr 30, 2012 at 11:45:37 am
Hi All
I've imported all my recorded movies from my camcorder to FCP with 'create proxy media' AND 'create optimized media' enabled. This resulted in a huge amount of hard disk capacity being used for the optimized media (> 300GB of the available 500 GB). I want to undo this or remove these optimized media files without FCP crashing or showing errors.
Can I just go the folder containing the optimized media files and move them all to trash? OR should I do this from within FCP so FCP knows these are no longer available?
Thanks for all help.
Philippe
Shane Ross
Re: remove optimized media
on Apr 30, 2012 at 3:41:21 pm
That is a question for the FCP-X forum. THis is the forum for older versions of FCP.
http://forums.creativecow.net/fcpxtechnique
Shane
Little Frog Post
Philippe De Neve
on Apr 30, 2012 at 5:18:10 pm
Ok. I'll post this in the correct forum.
